Help with 35mm lens
Monz
Monz
1:52 PM
UK
Dear RFFers,
I am thinking about getting a 35mm lens and have been looking at the following item...
LEICA Leitz Summicron f2 35mm Lens with eyeglasses
Serial no: 1746223
I looked it up in Erwin Puts’ "Leica Lens Compendium." From this source, I found out that the serial number makes it a series I lens (1958); Puts’ write up of this lens sounds a bit mediocre with mention of flare, vignetting and coma.
Has anyone here used this lens and is it any good? Or should I get something more modern? With the specs removed, will it fit on a M6?
I want something fast (preferably f2 or faster) and sharp. Bulk isn’t that important.
I’d be grateful for any advice.
Monz
Hi Monz,
Dan just put up his revised pricing table for the 35mm M lenses, and he mentions in his write-up on the Version I lens that some claimit is best B&W film lens ever made. It can't be that bad. I have one like it and I love it.
Raid
Thanks Raid. Do you know if the version 1 lens (with specs) fits onto a M6 (with the specs removed)?
Monz
You need to be careful using the M-mount lenses with goggles, which were designed for the M3. I suspect--but don't know for sure--that the lens brings up the 50mm frame and reduces the virtual image so that it is the 35mm field of view. If you remove the goggles--you may get only a 50mm frame and field of view. You should try it on your M6.
Thanks Santafecino; that makes sense. Unfortunately I don't have the lens in the flesh to try out on my M6.
Monz
Monz: The lens can be mounted [with goggles] on any M body, but you would see the 50mm frames. Do not remove the goggles.
Raid
Thanks Raid. I think I am going to pass on this lens after all and keep my eyes open for something more modern.
Monz
The J12 and a LTM/M adapter can be real cheap, I use one when there is risk of damage, as I cannot afford a replacement lux, it flares about the same as the lux.
Noel
I do not know about removing gogles from such a WONDERFUL lens. I almost would look at alternative lenses or bodies. Perhaps swap out the M6 for a body with a M3 magnification finder. Perhaps a preasph 'Cron or even a 40/1.4 CV with a bit of a modification to bring up the 35mm frame lines on an M6.
That sort of modification just does not sound good long term (for the next owner of the lens).
B2 (;->
