FrankS
Registered User
mr_phillip said:The softrelease screws into the remote shutter release mechanism inside the shutter button and provides a few advantages.
First, it physically raises the height of the shutter button, allowing you to use the joint or pad of your finger to fire the shutter rather than the tip. This results in a smoother action, more like squeezing a trigger than prodding a button, which reduces camera shake a little and is (to many people at least) more comfortable. Generally, the cable release socket also has a smoother action than the shutter button, so the softrelease turns it into something of a hair-trigger, which again helps reduce camera shake. The effect seems to vary a little camera-to-camera, but I find them essential items on my M6 and Canon P.
Most users experience a combined benefit of about a stop more usability in hand-held shooting: so if you find that you can normally manage sharp hand-held shots at only 1/30 a softie should allow you to go down to 1/15 and achieve the same results. Personally I find that, with the softie in place, I can manage decent shots of 1/4 second quite easily, and even 1/2 if I'm lucky (I must have steady hands).
The only downside is, as Steve says, you do tend to end up with a few shots of the inside of your camera bag, unless you get into the habit of stashing the camera without winding on first. That said, film's cheap.
This is true of a cable release which has a central plunger that actuates the shutter without depressing the shutter button, but that is not how the softrelease works. It does depress the shutter button, so the cable release benefit does not apply here.
(Sorry - picky, picky, but I mention it for the sake of accuracy.)
