S
sreidvt
Guest
rover said:Wonder if it is a measurement with the CV hood.
Hiya Joe,
It must be.
Sean
back alley said:he's ralph...i'm joe.
joe
Avotius said:I got a 35mm p2, after a few weeks of use the black paint started to wear on the tab but not much, and now after a few months of use the barrel is coming loose, needs the notorious tightening, and for that reason alone I would not buy another, that and they dont make any other lenses that interest me except that 15mm
Joe Mondello said:Given the often wonderful reviews that the new Cosina Voigtlander RF lenses get from Sean and others, plus the relatively low prices (especially compared to Leitz and Zeiss glass) why WOULDN'T you purchase some?
I have 5 CV lenses for my M8 and think they are terrific. BTW, they are not cheap, they may seem inexpensive by comparison, but Nikon and Canon MF primes (at least for SLRs) are usually in a similar ballpark price-wise.
cme4brain said:I have all CV lenses- the 15mm, 21mm, new 25p, 28mm Ultron, 35mm f/2.5, 50mm Nokton, 90mm Lanthar. I am debating on whether to buy the 75mm.
That's probably because it isn't a problem? I've got two CV lenses, one of them focuses to 0.5m, the other to 0.7. Of course a dual range Summicron comes closer, but then it obviously is a different focal length. There are some CV lenses which don't come that close, but then (1) there are Leica lenses with don't either, so this is really a lens vs. lens and not a brand vs. brand argument, and (2) if you absolutely and critically want close focus, a rangefinder isn't the best tool anyway.dseelig said:Teh one negative that never gets talked about is close focus
Bertram2 said:Higher contrast in general can mean less resolution = detail, but this does not concern only the midtones. and if any lens tends to a "milky look" then it is rather the one which is designed for more resolution. That is why I found "milky and undefined midtones" contradictionary to all my experiences with CV and for example Leica, which is designed for more resolution.
Bertram
Joe Mondello said:The 75/2.5 Heliar was recently reviewed by Sean Reid on his website. I think it's a terrific lens and quite a steal at $299 (really hard to go wrong!)
Here's a picture I took with mine last week . . .
More here . . .
http://www.flickr.com/photos/musicandlight/sets/72157600225465265/
jaapv said:Hmm.... and cannot be separated like this. Otherwise MTF curves would be totally meaningless.
scho said:I use ONLY CV and Zeiss lenses on my M8. I see no reason to spend 10x more for Leica lenses that don't produce 10x better image quality. The only Leica lens I might consider at this time is the new 28mm 2.8 asph, which altough reasonably priced is essentially un-available and I'm not convinced that it would give me "better" images compared to my 28mm Ultron.
vrgard said:Nice shot, Joe. And just when I was thinking that mine was becoming redundant and therefore, perhaps, should be sold...![]()
-Randy
