Xmas
The 1st Kiev I tried did not demonstrate your symptoms, it did seem to have a horozontal movement as the coincident spot was tracked across the gold patch, but no detectable vertical movement.
I dont think your symptom is due to the eyepiece movement, (you have done). It is more likely that someone has reglued one of the (two) rangefinder 'prism' elements, slightly out of alignment. Is the image concident at close up and at '8'?
Please can you try the same test as earlier with the concident spot just touching the bottom or top of the gold rectangle? If you get the same effect can you repeat at a different distance, preferably '8'.
The reason for the 2nd test is to see if the fault might be in the moving part (of the prism) or the stationary part, that way you need only to reglue the one rather than starting from scratch.
Noel
Noel
