R
ruben
Guest
Let me start clarifying with which hat I am speaking at this post. This is not part of the Kiev Project, although my next posting within the Project will deal with the same, in different order, extensively, and with pics. Therefore the following is not to be taken as an example, as now I am talking to the gearhead prone people, sending them to prove first the dishes I will be cooking for participants of the Project, somewhat like those unfortunate fellows who had to taste the food the King is going to eat, so that he will not be poisoned.
Now lets plunge. The subject here is softening the Rewind Knob, and choosing the level of stiffness/softness of the the Shutter Release Knob. Both in the Kiev 4AM model, which continues to surprise me as the real Kiev 5 of Soviet re-design.
Tip for softening the Re-wind Knob
As we all know, the general stiffness of all Kievs results from the total accumulation of friction between gears. This total has its first station at the Re-wind knob.
What makes the re-wind knob stiffen of soft? In case the camera has not be cannibalized and remains as sent out of factory, there are two factors controlling friction. The most obvious one is dirt or stiffen grease. The other is a small spring, hidden inside the fork engaging the film cassette, which can be adjusted to the taste of the user, via further turning on, or releasing, the visible screw at the fork throat.
The news is that this spring can be replaced by another one, much softer, already existing in our camera, lazily sleeping without much use. This softer spring is the one found immediately below the shutter release knob.
Therefore, if you like the idea, you can take the soft spring and install it at the Re-wind knob fork, after you have cleaned everything there around, and adjust friction level, "a la carte". My taste is that the Rewind Knob should be ABSOLUTELY free from friction. As much as possible of course.
Tip for adjusting the depht of the Shutter Release Knob
Along the years we have come to meet different shutter release knobs. Some are extremely far from the actual firing point, as for example the Yashica G series, some are extremely short , as for example in the Yashica Lynx 1000, and all the others in the middle with their tendencies to either camp.
Personally I love the short travel one, and this is the type found at all Kiev and Contaxes for my luck. But it seems to me that from all Kievs, the one at the Kiev 4AM/Kiev 4M has the shortest travel. Therefore hereby I offer you three levels of travel depht into the center of Earth.
a) the shortest travel is when you remove the exististing spring below the shutter release knob. The camera has no problem at all in any sense with this arrangement.
b) The medium level travel is with the original spring comming with the camera, the same spring I said above it can be better used for the Re-wind knob.
c) The longest level travel ( always within the cathegory of short travel) is if you choose to install the relatively hard spring, formerly placed by Arsenal factory at the fork of the Re-wind knob.
I myself still prefer having my 4AM without any kind of spring below the shutter release knob, but it is a matter of purely personal taste. "A la carte".
Ruben
Ruben
