It's getting hot these days ...
steamer
6:30 PM
Minneapolis via Tokyo
The chemicals (D76) are about 26 degrees centigrade today, how do you deal with this? Put em in the fridge? an ice water bath? Crank up the aircon, wait for Winter? I've only been developing film for a short time, haven't done it in warm weather yet.
I mix D-76 1+1, so I use water that is colder than my D-76 to arrive at a temperature I can use. If you use D-76 undiluted, then yes, I'd suggest the fridge for awhile.
I like Sam's suggestion, too.
As to the fixer and so on - it is important that all the liquids that touch the film be as close to the same temperature as possible, because a nasty bugger called 'reticulation' can cause problems when something appreciably colder or hotter than the film's gelatin touches it while it is wet and soft.
With that being said, in my opinion, a few degrees difference are not that big of a problem. I think to have reticulation the difference must be fairly large. However, I could be mistaken on that.
I take 1 gallon drinking water bottles and fill them then freeze them. I have a homemade sink that I fill with water and place these frozen bottles in and place the processing chemical bottles in it to cool them off.
The problem with converting the time using the graphs is when dev time gets around or less than five minutes. Small timing errors with short dev times cause big problems. Longer dev times absorb small timing errors better. That is one reason I usually dev D-76 at 1+1. Besides being slightly more economical (well, if you use D-76 as a one-shot anyway), and giving slightly higher accutance at the expense of grain, it also gives me around 8 to 10 minutes dev time, depending on the film. Straight D-76 is already too close to five minutes dev time to my liking - adjust for warmer water and you're looking at 3 or 4 minutes with some films. Way too fast. Make a 30 second mistake there and you've got problems.
Normally, adjusting time for temperature is fine, but I try to avoid short dev times, and that's what you'd get with D-76 straight. Just my 2 cents.
I do it simple 🙂
Mix water form fridge at 12 degree with drinking water at 26 degree up to 20 C.
Now I dilute my developer and fixer and put the liquids in big dish full with 20 C water (I live in dessert area with 38 - 40 C at this season). Thermometer is in the dish and I hold bag with ice cubes in standby. I work in clean area. The water in the dish will be used for stop and finaly for rinsing using Ilford Rapid Fixer (short procedure. See how this is done from the Ilford fixer pdf file).
I like the action. I am in between 20.2 and 19.8 C.
I finally souped a roll of Fuji Across 100 in 1:1 D 76 for nine minutes at 22 degress. Cooled the developer with the diluting water as Bill suggested, and put the fixer, etc., in the freezer for a bit. The negs look good, I will see when I scan them after they dry.
I've been struggling with the same problem here --- not helped by the fact that my darkroom, such that it is, is in the Attic -- turns into a hot torture chamber by the first of July. I recently started developing film down in the basement (helps a bit). I also use *frozen* plastic bottles of water to equilibrate my water bath-- it's important to circulate the water when you do this, I have used a relatively large picnic cooler + aquarium pump with styrofoam floats/cutouts to hold the chems.
My husband recently took pity on me a found a used Jobo TBE to help maintain the temp. Looking forward to trying that out.
JT
JT
If you're interested, you can also look at the so-called "Panthermic" developers, in which development continues to completion and stops, so time/temp are less relevant. There are trade-offs, there always are, but google for panthermic developers and you might find something you like.
steamer said:
Turned out OK, looks like a roll I took with the OM2 (an honorary rangefinder) hope no one minds if I post one shot.
Could just be my monitor, but that image looks very contrasty to me. I see a lot of white and a lot of black and not a lot of in-between. I am wondering about your dev time - is it possible you overdeveloped it?
Steamer: The occasional OM shot is always welcome. I've posted (gulp) one or two. 😀
I agree with Bill, they look contrasty, but that could be totally unrelated to temps ... could be time, as Bill said, or the scan/curves.
Better, but it looks like a very contrasty scene to begin with. Asian black hair is often as black as black gets - and you're lost some detail here. However, it looks like this is what, a beach? On a bright sunny day? If the sand is very white, the range of possible values here appears so large that no film could contain it. A tough photo to pull off.
Diafine developer may be an option here. It is, as Sr.Guapo sugested "Panthermic", and has works well in contrasty, mixed lighting scenes.
Robin
