12mm heliar dimensions, i need help
12:25 PM
if you own a voigtlander heliar 12mm i need your help. i want to adapt this lens to a shuuter and need to know some dimensions from it. I nedd to know how far the rear element protrudes past the mount flange and how large in diameter the glass of the rear element is and the diameter of the housing for the rear element. thanks for your help and i hope someone can help with this info
