15mm Rattler !
Glenn2
6:38 AM
Vancouver Island
Have just noticed that my 15mm lens has a bit of a rattle if shaken. Is this normal for these critters? Images are fine so don't think it's a loose element. Just wanted to catch things early if somethings coming apart. Many years ago had an SLR lens jam because a screw had vibarated loose inside. Wouldn't want a repeat with one of my favorite lenses while far from home.
Glenn
M4, 15mm CV @ f/4.5 Fuji 400
Glenn,
mine doesn't rattle. I did have the back off today which is just 4 cross screws on the screw mount. remove mount noting a small dot on mount which lines up with dot on aperture scale. remove the shim and there are 4 screws under there, maybe its one of those? other than that i would send it off for a check up!
regards john
Pesky diamond backs...
Lens rings do come undone I've had a J8 (FSU 5cm) and a Elmarit 28mm (leitz) loosen up. I'd ship it or take it to repair shop.
Noel
