2 - nd color roll with BESSA - Rokkor combo
PetarDima
3:36 PM
two portraits
B&W conversion
night shot - lopng exposure from hand
very important question for BESSA users:
Does framelines in short distance -0.8 meters to 1.5 meters are 100% correct?
I think that I had a lot of hands & other parts missing on my shots :confused:
Hi Vlad,
the 40mm matches the 35mm R2 framelines down to 3m or so. Below that
you have to give the framelines a little room (10-15% at closest distance) ,
or switch to 50mm framelines for composition.
Best,
Roland.
Very nice photos. I especially like the first one, so much texture and detail. I have used the inside of the 35 framelines successfully on a R2 and Rokkor 40, but I try to leave a little extra room usually.
ferider said:
Hi Vlad,
Best,
Roland.
thank you RFF friends :) I'll remember this - I haved used 35mm framelines only - one day I'll be happy to try 28mm lenses ... that will be perfect set with
SUPERIOR-SHARP Rokkor.
There is great character in this woman's face, Petar. Is she a relative?
I haven't been following your threads, so I'm not sure which Bessa you are using with the Rokkor. I found the 40mm framelines on the R3 Bessas quite accurate, but if you're using 35mm framelines on an R2 or R4, you'll have to be careful close up, as people are suggesting.
Yes :)
that is my 85 years old grandmom - few years ago she worked hard in village, but the oldness and weaknes are coming ... never mind she's eyes are tired, but always full of life!
I use BESSA R2M - this photos are result of RFF donation :) .
