21/24 rf-coupled lenses ?
pdh
1:48 PM
I'm wondering if there are any rf-coupled 21mm or 24mm lenses - other than Leica, Zeiss or Voigtlander - that will mount on a Bessa R2A.
The "big three" makers are beyond my pocket at present and I prefer not to scale focus.
The Bessa's body precludes the use of any of the FSU wides because of their deeply projecting rear elements, as I understand things, so they're already ruled out.
I've googled a bit but haven't come up with anything yet. So will be interested in any suggestions
All I can think of is the M-Hexanon 21/35 -- but if you can't afford a Voigtlander lens you definitely can't afford one of these rare birds.
There was a screw mount 25/4 Nikkor, I believe, but I bet that's really pricey if you can find one.
I do not know whether adaptors exist to convert Contax-mount lenses to M mount -- I assume when you say "Zeiss" you're referring to the new Cosina-made M mount lenses. The older CZ lenses are top quality, even 50+ years later, and may be less expensive because the Contax mount is defunct.
The Canon 25mm F3.5 LTM is rangefinder coupled.
Great lens. Got mine for $550 after years of searching for it.
i don't think you have a cheaper option. by far the cheapest is the skopar 25/4 (cheapest modern ltm/m lens in general) but as you know it's not rf coupled (great lens though, my favourite ever, actually). Of course you could get a cheaper m42 slr lens or something and use an adapter but then you'll go uncoupled, too and more bulky of course.
I say, if you really want that focal length and can spend 250$ or so, get the skopar. I was sceptical as well first but now i even see the scale focusing with click stops as advantage. really hard to get something out focus with that one...
Ah! Thank you Mr. Hicks. That information helped me find this page which lists the alternative names:
http://www.cameraquest.com/koba21.htm
CameraQuest said:
sold under a variety of names including Kobalux, Avenar, Bower and Pasoptik -- among others.
thanks also to all the other respondees of course.
The 25 would be attractive were it not a bit oo close to the 28s I already own.
I think Contax-M adapters probably cost as much as a lens.
And yes, I was thinking of the older CZ lenses.
If you find the CV lenses too expensive, you might be in trouble. A lot of alternative wides have become rare and expensive. Forget the Hex 21/35 Dual. That lens goes for over 2K now, as so few were produced.
Minolta Made some rangefinder lenses for the Leica a few years back they made a
28mm, 40mm, and I think a 90mm as well they were in M mount as well.
Range
