einolu
Just saw this and it looks very interesting:
http://www.fedka.com/catalog/produc...d=215&osCsid=d9078f54c82d05e9c9912c86616b9dae
has anybody tied one. Someone told me that fed lenses wont always fit on LTM cameras, is this true? I dont think I will buy it but Im curiouse how the 'ultrawide' lenses of the past preformed. Also it looks very cool
Anyway..,
Anyway..,
doubs43
According to Princelle, this lens was only produced in 1938 & 1939 in very limited numbers. If there's a serious collector of FSU rangefinders around, that lens should sell rather quickly I'd think.
I have the later 28mm f/6 Orion in mint condition. It takes a very nice image.
Walker
Walker
John Robertson
I too have the Orion, its a great lens. The Fed however is a different construction optically, more like the 28mm Hektor of the same era. I also had a Hektor , but the Orion easily outperformed it. You can see the Orions construction here.
http://www.zenit.istra.ru/archive/lenses/orion-15.html
Use Babelfish or similar for a translation.
einolu
I can read russian, just very slowly (thanks for the link!).
John, what do you mean by "outpreform"? The fed seems to be faster than the orion, I hear that contrast is a bit low on those older lenses but besides that what could be wrong with it (except for the price)?
I was just curiouse really, I might be getting a wide angle lens soon but am leaning more towards the CV 21 or 25...
John Robertson
The Orion is a much more "modern" lens, and being coated is less prone to flare, and better with colour. It is also fairly distortion free. Remember the Fed is an old lens 60+ years, it is however quite collectible and has value as such. The CV lenses you mention are excellent, I have both. My favourite CV however is the 15mm, very sharp, but requires more care in using to avoid drunken horizons!!!
See
http://www.rangefinderforum.com/cpg/displayimage.php?album=192&pos=94
don't let me put you off the Fed, however, I note however the description says its slightly hazy!! that could give you problems with very low contrast.
See
Zorkiiglaza
OK! I just dug out my Fed 28 lens and mounted it on a Leica 3F.
The latch knob stops at 1:00 - focus doesn't correspond to distances on the lens barrel.
I then mounted it on a Zorki 1- same identical problem.
So my guess is that it MAY only work on a prewar FED.
Next I have to try my FED 100....another day
einolu
Thanks for clearing that up.
John Robertson
I've heard that pre-war Feds were set to a slightly different register to Leica.
kiev4a
The pre-war FED lenses had a different lens-to-film distance. They also had a slightly different thread pitch than the standard LTM lenses so they won't work properly. A lot of folks who want to shoot the pre-war FEDs replace the original lens mounts with one from a post-war FED or Zorki and adjust the LTF distance.
