Bill N
What 35 would be recommended for my Canon P?
Thanks!
Thanks!
presspass
filmshooter
Let me be the first to recommend the f2.0. A wonderful lens with attributes of modern and more classic lenses.
Darinwc
The Canon 35mm f2.8, f2, or f1.8 are all excellent.
The f3.5 not so much.. it is only a 4 element lens.
There is also a f3.2 which should be good as it is a 6 element lens but I have never had one.
The Leica summaron had a good reputation.
Any of the Voigtlander 35s are excellent.
Retro-Grouch
If you are on a budget, or even if you're not, The Jupiter-12 is superb, if you get a good copy. Buy from a reputable dealer such as fedka.com. Mine came from that site, and I'll put it's performance and rendering up against the current ZM 35/2.8. It's that good!
Pioneer
I am currently working exclusively with a Voigtlander Color Skopar 35mm f2.5. A very nice lens with no major problems that I have found to this point. I can recommend it.
While the one I am currently working with is an M-mount version I have found the LTM mount version to be pretty much identical.
agentlossing
Voigtlander 35/2.5 Color Skopar is nice and small and would fit in very well aesthetically with the Canon.
Mackinaw
Think Different
The f3.5 not so much.. it is only a 4 element lens. There is also a f3.2 which should be good as it is a 6 element lens but I have never had one..
The 35/3.5 is a Tessar-based lens, the other Canon 35mm lenses are Gauss-based. Each have their own unique optical characteristics. Up to the shooter as to what you prefer.
Jim B.
bluesun267
Nikkor 35/2.5. A tiny gem, super sharp with a certain 'bite' the Canon f2.8 and f1.8 don't have (I haven't tried the F2.0 yet). It also has some of that vintage swirl wide open. It seems to have gotten hard to find lately however.
Bingley
I have the Canon 35/2.0, 35/2.8, and the Voigtlander Skopar 35mm f2.5 PI. I would recommend the Canon 35/2.0 w/out hesitation; ditto the Skopar 35/2.5. They render differently, of course, but they’re both v compact, v sharp, and v well constructed lenses.
Thoughts on the Canon P: beautiful camera, very rugged, but 35mm framelines are really hard to see if you wear glasses. This is a camera that excels for 50mm and 90/100mm shooters. That said, if you can find a Canon 35/2.0 in good condition, I’d go for that. It’s such a lovely lens! If you can’t find one of those, then I’d look for a CV Skopar 35/2.5.
jcb4718
I agree 100% with Bingley. The Canon 35mm f2 is a great lens. The Skopar 35mm f2.5 (which I also have) is also a great lens, but different. If I had to choose I would keep the Canon but actually I keep both. The Skopar seems more contrasty and if the scene is high contrast the images can seem a little harsh. I have taken apart both lenses to lubricate and the engineering of the Canon feels better but both I'm sure are adequate.
johannielscom
Snorting silver salts
For great sharpness and a sixties contrast: https://www.ebay.com/itm/333872006097?hash=item4dbc5283d1:g:sFoAAOSwWYtgEzGY
I have a 3.5 version in brass (takes a while to find one, most of them are alloy under black paint) and it is magnificent:
Through the ages by Johan Niels Kuiper, on Flickr
charjohncarter
Some of the best lenses are four elements: Tessars. I have a Serenar (Canon) f 3.5 35mm lens that is prone to haze, I easily clean it myself. Most people that have never used this lens almost universally describe it as soft wide open.
I did a test wide open:
full frame:
Neopan Acros 100 expired by John Carter, on Flickr
edge blowup:
center blowup:
I can't really in real life tell the difference between this lens and other lenses with more elements.
I would not recommend it because of the haze problem but I use it and never have thought it 'soft.'
full frame:
edge blowup:
center blowup:
Larry H-L
Just a note of caution on a Jupiter, I vaguely recall that some versions of the J-12 lenses won't mount on some Canon bodies because of internal baffles in the cameras. You might want to research that issue.
retinax
The baffles can be (gently!) bent out of the way. But maybe there are combinations where that's not enough, I don't know.Just a note of caution on a Jupiter, I vaguely recall that some versions of the J-12 lenses won't mount on some Canon bodies because of internal baffles in the cameras. You might want to research that issue.
My Jupiter-12 is reasonably sharp and draws nicely but suffers from a) field curvature and b) quite a bit of pincushion distortion. I think it's sharper closer up than near infinity but I haven't done systematic tests.
Some people find the aperture ring objectionable but I can live with it. The great large focusing ring and super quick to read/zone focus distance scale make up for it.
Arthur
And there is the LTM Leica Summicron 2/35 ASPH if you find one for sale. ��
bluesun267
No love for the Nikkor?
das
For LTM, here are some suggestions.
The VC Color Skopar 35/2.5 is going to be the best considering cost/performance.
If you want to spend alot of money, the Konica UC-Hex 35/2 or the Leica Summaron 35/2.8. But neither of these lenses is clearly better than the Skopar.
For cheaper vintage options, the Canon 35/2 or the W-Nikkor 35/2.5. The Canon is more modern, smaller, and easier to focus.
Erik van Straten
The four element Elmar 35mm f/3.5 is very small but is a great lens. The uncoated ones are almost as good as the coated ones, but are easier to clean. The coating of old lenses is easily damaged. The six element Summaron 35mm f/3.5 is very nice too. The f-stop of this lens is more practical than the one on the Elmar.
Erik.
Erik.
Erik van Straten
gelatine silver print (summaron 35mm f3.5 ltm) leica mp
Erik.
Erik.
Doug A
I have two Nikkor 35's in LTM mount, the 35/3.5 and 35/2.5. The 2.5 is the sharper of the two at the same apertures. Neither has the contrast of a more modern lens like the 35/2.5 Voigtländer I sold because of some mechanical issues. Of the three, my favorite for B&W is the 35/2.5 Nikkor.
