35mm summicron type II
JayC
5 kids,3 dogs,only 1 wife
8:11 PM
I have a line on one, but cannot find much info on it. The AOL site says "Contrast is improved over Type 1, but resolution is not quite as good." The one I might buy is a very early serial number in the Type II range and is made in Wetzlar. It has the little tab to change the aperture.
That's about all I can seem to find. What do y'all think of this one? Any sample pics? I recently bought a 35mm Biogon. I can sell the Summicron for what I will pay for it - no problem.
Thanks for some help.
The description you read is accurate. The number was elements was reduced from 8 (in the version I) to only 6, as an economy measure. In the process, the number of glass to air surfaces was also reduced, which improves contrast; but at the same time, abberations were less well corrected. The version III was more similar than different.
Later, when the version IV was designed, the design was upgraded to 7 elements. With the better optical glasses then available, the abberations were once again highly corrected.
In practice the differences are subtle. Versions II and III are still good lenses.
