35mm Summilux or Summicron?
HuubL
hunter-gatherer
6:34 PM
Netherlands
It seems I got a new 35 mm lens in the mail: a Summilux v2. I already have a v4 (king of bokeh) Summicron and it seems senseless to keep both.
Considering that both have excellent glass, that the cron has a bit more signs of use on the barrel, and the current value, which one would you keep? Is that based on performance? Is one clearly better than the other?
I have both, and I use both. Do I really "need" to use both? No.
Why do I have both? Because I want to try them out.
Would I sell one of them? No.
Why not? Each lens has different qualities. and such lenses appreciate in value over time.
My suggestion is to try out the lux v2 and see how you like the rendering and the performance wide open.
I love my lux V2 (infinity lock version) but I consider it a special lens, hence I also use a summaron 2.8 (for me a perfect 2 lens kit for a standard and a full of character 35mm lens on two M2s).
I never use a cron v4 so I can't comment on this specific lens.
Good luck with your final choice.
Giulio
Thanks Raid. Increasing value over time would be a legitimate reason to keep both. Especially in these days of low/negative interest rates. However, do classical cameras and lenses still increase in value? I haven't seen a recent update of the lists on antiquecameras.net.
Because I had the chance to find one for a good price....
What's your SECOND question...?
Yay, so I would suggest that you keep using the lux for a while and see which one you prefer.
Personally I have switched from 35/2 iv to the summaron 35/2.8 for a while (3months) and concluded that I much prefer the summicron. I have no experience with the lux anyway.
I would make a test of both at the same time. If they perform identical, I would keep the best looking one.
The "king of bokeh", the Summicron v4 lenses, are made both in in Canada and Gemany. The Germany-versions are newer and more expensive. There are also examples in chrome. These are very sought-after. The Canada-versions have often mechanical problems.
The Summilux pre asph v2 35mm lenses are also made both in Canada (early) and Germany (later). I have a very early Canadese version, 2221365 (with infinity lock), that is an awful performer, but looks like new.
Erik.
My answer also. I have both and it would not occur to me to sell either.
How about 'cron vs con!
You aren't alone here: I just ended up with two Summicrons, v 3 and v4. Long story but I imagine I will sell one off before too long.
Closer to your situation, one time in the 90s, I found myself with a 35 Summilux v2 and an 35 Aspheric Summicron which was relatively new on the market. I loved the Summilux in most aspects and very much for it's size and handling, but didn't personally find it very useful wide-open so I sold it. I really liked the Aspheric but not the size so much. I eventually sold it off. If I could get one back, it would probably be the 'lux.
More recently for my first M9, I picked up a Version 4 Summicron. I liked it very much and made very nice enlargements with that combination. Fast forward to the past couple of weeks, with an M9 again and these lenses, did a quick comparison of v3 6 element and v4 7 element lenses. While not extensive, I can say that I'd be really hard pressed to tell the difference between these two. The version 3 is a good deal in a 35 Summicron, and I like the physical build and design of the version 3 as well.
In your case, at least the two are different. Good luck choosing 🙂
David
Erik.
Thanks Erik,
Mine is #3254023. Would that be a Canadian or German version?
My Cron is made in Canada and I don't have complaints.
I've got both I reckon the summilux does not catch up with the summicron until f2.8 maybe even f4, I always kept it because I liked it on my m2 and it meant I could carry m9 with the summicron and m2 with the summilux. I also would never sell the summilux because it only cost me around £250 about ten years and I can't see me finding another one so cheap!
BTW, If I have to keep them both, I'll sell one of my Summarons shortly. And that goes with another question: LTM, dual mount or M-mount?
I had both and recently sold the Summilux. The Summicron is sharper at f2 (the aperture I would tend to use the Summilux), and the cron is smaller. I couldn't justify keeping the lux for digital; I'd only consider keeping it for that useful change in character going to F1.4.
Pete
I've done nothing but lose on lens sales.
Pete
The Summilux 35mm f/1.4 pre asph steel rim is the best of them all. That is my subjective opinion.
Leica M5, Summilux 35mm f/1.4 pre asph steel rim, Tmax400.
Erik.
I think you need to sell the Summilux to me. 😉
Well, what you lose is sharpness wide open, 30 centimeter of the close range and a few grams of matter. And you need to get a 12504 hood and a series VII filter (cheapskates use a reversed 49 mm filter).
Either lens of the above is good - what you need is to point it at something interesting and the rest will take care of itself.
