4/3?
ernesto
1:00 AM
I wonder the meaning of 4/3...
4/3 is the same as 1 and 1/3, but I wonder of what.
Any hint will be greatly appreciated!
Ernesto
I understand it is officially derived from the sizing of the sensor - 4/3" -, based on old video camera sizing. Probably better to consider this than the aspect ratio, particularly given the newer m4/3 multi-aspect sensors.
Quote from wikipedia:
"The name of the system stems from the size of the image sensor used in the cameras, which is commonly referred to as a 4/3" type or 4/3 type sensor. The common inch-based sizing system is derived from vacuum image-sensing video camera tubes, which are now obsolete. The imaging area of a Four Thirds sensor is equal to that of a video camera tube of 4/3" diameter. [3]"
So it is not a fraction, but a proportion.
To a mathematician, the two are equivalent.
The 4/3rd's consortium chose to use fraction notation (long side is 4/3rds the length of the short side) instead of the more common ratio notation (e.g. 4:3). You see the same dual notation when discussing the speed of a lens. There is f/stop notation, where "f" stands for the focal length, on most markings and most discussions, but "focal ratio" notation is used on the lens barrel's markings (e.g. "50mm 1:1.4").
Yup. Nothing to do with the aspect ratio. The best proof is that the Panasonic GH1 has an oversized sensor allowing it to shoot natively in multiple aspect ratios (4:3, 3:2, or 16:9) with a similar angle of view. My E-P1 can also shoot in 1:1 (square mode), although with a slightly reduced resolution.
Aspect ratios normally use the proportion notation (4:3), while sensor sizes use the fraction notation (4/3"), so it makes sense that the 4/3rds format also uses the fraction notation.
Cheers!
Abbazz
Other sizes than 4/3 are crops, because 4/3 is the max. size of the sensor. Well, size is obviously not the right word.
In fact, 16:9 is a crop from 4:3 with most cameras, but not with the Panasonic GH1. The GH1 has a larger sensor, thus allowing three different aspect ratios (4:3, 3:2 and 16:9) while retaining the same image diagonal (image circle). Please refer to the Panasonic website for further explanations:
http://panasonic.net/avc/lumix/systemcamera/gms/gh1/high_image.html
Cheers!
Abbazz
The GH1 sensor is great - you can choose the aspect ratio you want and know you are not wasting any sensor real estate by cropping. Hopefully this will be implemented in the future new m4/3s models.
From DPReview:
Actually, the aspect ration is not scientific at all.
It really comes from what is much more common.
In the US and much of the world......
4/3 is what most Television screens are....
16/9 is what most HD TV is....
3/2 is what 35mm usually is.
By using the above relationships, the eye has a more natural native eye travel.
So, to ask another stupid question: Is a 4/3rds sensor 4/3 of an inch in length, i.e. 1.33 inches?
/T
No, it's not. That's the problem I have with people claiming it's "4/3 inches." The attribution that it's based on the NTSC video format's aspect ratio may be true, but it ain't 4/3 inches (which would be 1 and 1/3 inches) in size.
According to the Wikipedia article: "The sensor measures 18×13.5 mm (22.5 mm diagonal), with an imaging area of 17.3×13.0 mm (21.6 mm diagonal)." This is roughly 1/4 of a 135 format film frame. The diagonal (22.5mm) is almost an inch, but not quite.
~Joe
Let me add (also from the Wikipedia article):
The 4/3 inch designation for this size of sensor dates back to the 1950s and vidicon tubes, when the external diameter of the video camera tube was measured.
There's a very useful page on DPReview summarizing the sensor sizes:
http://www.dpreview.com/news/0210/02100402sensorsizes.asp
Cheers!
Abbazz
