6 bit 40mm Summicron
Fraser
6:39 AM
Does anyone know if 6bit lens mounts are available anywhere for the 40mm Summicron I've changed all my other lens mounts to 6bit but the mount looks different.
Cheers.
Cheers.
My 40mm German made Summicron came with a normal M mount which I then marked with a 6 bit code and it works well.
I was also looking for one but even with the large offer of 6bit mounts on ebay I didnt find the one to fit the 40mm Summicron.
I would be also happy to find if there is one that fits.
Cheers.
Yes I could do that and maybe I might have too but it would be much better and just as easy to change the mount.
During CLA and a bit of grinding to bring up 35 framelines, DAG sent the mount to John Millich for milling and the coded it as a 35 Cron. There's a screw under one black dot, but that's OK.
Kirk
