CV do in that they make a 50/75 adapter. This will bring up the 50/75 framelines on the M6 etc. For the ZI, it would be your choice. If you prefer to frame outside the 85 lines, use a 28/90 adapter. If you prefer to frame inside the 50 lines use a 50/75 one.
Altenatively use the CV 75 finder. They are very good. 😉
Kim
kshapero said:
I don't think CV makes a 75mm adapter, so should I assume the 28/90 adaptor will bring up the 85mm frameline?
I use it with a 28 - 90 adaptor and if you just think outside the 85 frame lines on the ZI it is "just about" right. But if it is really critical on the edge (though I find this so rare to be non existing) of the frame then you can bring up both 85 and 50 frames if slowly flip the preview. Or as Kim and Back both said use a 75 finder. As i tend to rarely use 100% of the frame shot and now scan all my negs using the 85 frame lines works wonderfully for me
