rodneyAB
rodneyAB
35mm and 75mm combo
35mm and 75mm combo
one photo per post??
35mm and 75mm combo
rodneyAB
35mm and 75mm combo
35mm and 75mm combo
the above post is meant as invite to post photos from your 35mm/75mm combo.
these two taken from the same chair
35mm and 75mm combo
djonesii
Rodney .... could you fill us in on the details .... camera, film, lens, f stop, shutter speed, all the usual suspects ....
Dave
Dave
rodneyAB
sure of course details...from memory...these are from august 6 2007.
Fuji neopan 400 rodinal 1+25 6min at twenty degrees, never mind my sloppy development technique. mp3 summilux 75mm summilux 35mm ASPH no idea what fstop or shutter speed.
since i read responses from Martin-f5's post that several consider the 35mm/75mm lens combo to be 'their' combo, i was thinking focal length from one position examples, so post some if you have them
Ororaro
rodneyAB said:the above post is meant as invite to post photos from your 35mm/75mm combo.
Aaaah! The Fatman's technique, as I like to call it.
venchka
I own 35 & 75 lenses. I plan to mount each on a body, load the same film in both bodies & see what happens. I'll be back.
toyfel
Like them both a lot, especially the second one! Thanks for posting them.
cmogi10
Bodhisattva
35
75
Sorry not from one position...I looked through a lot of images to find out but no dice.
Another 35
Another 75
75
Another 35
Another 75
Ken Ford
Refuses to suffer fools
rodneyAB said:
You're related to Martin Sheen?
rodneyAB
Ken Ford said:You're related to Martin Sheen?
yes, of coarse, brother in law
rodneyAB
cmogi10 i like the guitar player! the wallet detail on the right is kool
rodneyAB
toyfel said:Like them both a lot, especially the second one! Thanks for posting them.![]()
thanx much
rodneyAB
venchka said:I own 35 & 75 lenses. I plan to mount each on a body, load the same film in both bodies & see what happens. I'll be back.
great, i'll be watching
rodneyAB
NB23 said:Aaaah! The Fatman's technique, as I like to call it.
Ned you must mean it ain't over till the Fatman takes your photograph
Chris101
summicronia
I hope neither of you ever gets shot by me then!rodneyAB said:Ned you must mean it ain't over till the Fatman takes your photographNB23 said:Aaaah! The Fatman's technique, as I like to call it.
payasam
a.k.a. Mukul Dube
35 years ago my ideal kit -- which I could not afford -- was an M2 with a 35 and a 90. The 75 focal length did not exist at the time.
