lmmo
Hi!
I bought this lens on eBay and the seller never specified that it missed both lens caps.
The back cap isn't a problem to replace, but the front looks a bit more complicated.
Do you know where can I buy a cap for this lens? Is there any alternative, like using a standard 43mm cap? Will it work with the lens hood mounted?
Thanks for your help.
Mr_Toad
Fluffy Marsupial
Hi, Lmmo,
I'm sure you have this, but here's some specs from B&H...so it looks like a 43 cap should work...but with the hood....hmmmm...
Filter Size 43mm
f/Stop Range 2.5-16
Minimum Focus Distance 3.3'
Magnification Not specified by manufacturer
Zoom/Focus Control Not applicable
Angle of View 32 Degrees
Groups/Elements 5/6
Tripod Collar No
Length 2.5"
Maximum Diameter 2.2"
Weight 0.50 lb
And here is the CameraQuest lens chart...but it says "43mm, push on lens cap"...
http://www.cameraquest.com/voigtlenchart.htm
Robt.
Filter Size 43mm
f/Stop Range 2.5-16
Groups/Elements 5/6
Tripod Collar No
Length 2.5"
Weight 0.50 lb
Robt.
seifadiaz
I don't know where you are from, but you may be able to purchase a lens cap from a Voigtlander distributor (in Sydney, I know of a store which sells a cap). As for using standard lens cap, no experience with a 75mm, but I have no problems with using them on a 35mm & 21mm color-skopar (39mm).
lmmo
Thanks guys! I'll probably try a generic 43mm cap...
