88 mm filter
Bob L
1:40 PM
Does anyone know were I might be able to get a 88mm skylight or UV filter.
Need one for a 65mm lens for a kiev 88.
Or if not how about a adapter to a more common size.
88 mm filter
Bob, I suggest you get a 88 to 95mm step up filter ring plus a 95mm sky or uv...if you're very lucky --- they're all in ebay right now -- you should be able to get both for $25 to $35 in all...An 88 mm filter, for some reason, is enormously expensive...regards, bob cole
You might try ARAX, Gevorg is a great guy to deal with and usually responds pretty quickly. He takes amonth off for vacation in the summer, though, and I'm not sure just when.
Here is the link:
http://www.araxphoto.com/
Rob
step up ring
step up ring
Tried E-Bay , couldn't find any step up rings for 88 to 95 mm, If you can, can you tell me were you found them on e-bay?
Thanks
88-95 step up ring
88-95 step up ring
Thanks
________________________________________
bob, altho I sent you a PM, I see he says he's got 20, so I can tell you here: Ebay item No. 7623882812
regards, bob
regards, bob
Thanks Bob, Now he only has 19.
