90 2.0 Summicron on ZI
Penceler
3:15 PM
Any thoughts on the 90 on a Ikon? How is the focusing? Is this a territory best left to the SLR? Any thoughts on the Canada version of this lens?
Thanks (again) in advance.
John
I've used the 2.0/90 Apo-ASPH Summicron quite a bit on the ZI with very good results. The ZI focuses the lens without difficulty, and I have not had a problem using the 85mm framelines of the ZI to compose shots with the 90mm lens. In fact, I've gotten pretty good results using the 135mm apo-Telyt on the ZI, though that lens does require an accesory viewfinder for composition.
So go for it.
LJS
Works great on mine. Not a problem. Although I'm considering selling it because I just don't use it that often. But when I do the results are usually much better than I expect.
Short teles are great and many, many classic RF photos have been taken with them.
The 90/2 is great value (actually got cheaper with the M8) and should work fine on the ZI.
Roland.
