A .7m 50mm Sonnar
ferider
11:01 AM
Encouraged by Brian, I finally tried what we discussed several times in the past: modifying an LTM Nikkor 50/1.4 to focus down to .7m on an M.
Most Nikkor 50/2 and 50/1.4 LTM lenses focus down further, but decouple an M RF at around 3ft. The lens cam keeps moving, but the LTM mount of the lens stops the camera's RF cam. All you need to do to get closer focus is file a gap into the LTM mount.
Here are some pics:
0) remove the lens from the focus barrel by opening the spanner ring in the back.
1) put on your LTM/M adapter and mark with a Sharpy where the camera's cam will go.
2) remove the adapter, and file down a gap where you did the mark. Do this while the lens is set to the closest focus (to get the cam out of the file's way). You can check visually how much you have to file down, by moving the lens back to around 2.25 ft focus distance, where cam and mount ring should be parallel. The gap should have smooth corners so you can keep using the lens on LTM cameras.
Here is a Before/After picture:
Here with the M adapter on:
And here the new minimum focus position:
Roland.
PS: I put this post in the M section since I find it specific to M bodies.
Wow! I can see everyone pulling out their files for this!
Thanks for the detailed pictures.
Just to add- be very careful of filings getting into the Helical.
That's right. After using the file, blow away the filings with compressed air before moving the helical.
Roland.
File hell - I'm clamping the shop vac next to the lens and getting out the Dremel with the tungsten bit! :D
Roland and Brian - thanks for the tip.
Somebody asked me for a more detailed picture of what exactly I did. I changed the first picture in the original post. Best,
Roland.
I still have my Nikkor 5cm/2 LTM. It is a Sonnar, so it has to stay here with me.
haha, I just had an image of Roland getting numerous packages all from sonnar owners wanting this ,7 min. focus adjustment.
Just got my 50/1.4 Nikkor in the mail today. Going to try it out for a while. If I think it is one I'll keep for a long time, I plan to do this adjustment.
It's a beautiful lens, and actually smaller than I expected it to be.
Wow!!
Great!
Now my guess would be that some old adapters are focusing only to 1m, while VC are down to 0.7m right?
Soooo, you just file the adapter.
And now, for the good stuff...
Try to adapt a DR summicron to a leica III and to get it focus correctly down to 0.5m :p
Thumbs up Roland!!
Michael,
I can only recommend Leica adapters with the Nikkors. Always had problems with others, even CV adapters (do not align perfectly at infinity), I guess because the Nikkors have long throw. The Leica adapters don't need to be touched.
Best,
Roland.
