aureliaaurita
I have recently bought an e-p1 with kit lens and need to find a case for it.
I shall of course be seeking out a 1/2 leather case and strap for when it is actually in use, but I couldn't put it away without it being inside something that would protect it.
As these cameras are neither slr size nor compact it's hard to judge what to do for - I have had crumpler cases in the past and would ideally like to go for another.
What do you all use?
dfatty
I use a small timbuk2 messenger bag with domke padded inserts. The effect is probably similar to using a crumpler, and the timbuk2 is waterproof.
The e-p1 is small enough that you can probably use almost anything.
Good luck!
Good luck!
