williaty
Last, week, I accidentally bought a used Jobo reel from Latvia. When it arrived, I figured I'd better clean it as who knows what process(es) the previous owner was running on that reel. I soaked it for 48 hours in a strong solution of dish soap, then scrubbed each reel half down aggressively with a stiff-bristled scrub brush. During the scrubbing a LOT of dark gray foam flew off and splattered everywhere, so the reel was obviously dirty. Then I soaked the reel for 24 hours in a citric acid solution (10g/L) and scrubbed it with dish soap a second time. On the second scrubbing, the soap suds stayed bright white.
Am I done or should I also soak it for 24 hours in a sodium sulfite solution? I've used a soap and an acid, so I'm wondering if I should soak it in a base as well just to make sure I've got it as clean as possible.
What do you guys think?
Chriscrawfordphoto
Real Men Shoot Film.
The soap and water would have removed the acid. Just be sure you rinsed it in warm water long enough to remove ALL of the soap.
