A tale of four 50s
Gordon Coale
5:04 PM
Whidbey Island -- north of Seattle
Actually, 4 50mm lenses that will soon be three. My tabbed 50/2 Jupiter 8 arrived attached to a Zorki 4 from darkavenger. The Zorki 4 body is in better shape than my 3M although the 3M's internals have been massaged by Oleg . But it's the tabbed lens I'm interested in. The Zorki 4 body will eventually be a gift.
The glass looks pretty good except for some dreaded cleaning marks. The tabbed J8 has definitely been used compared to the mint later black J8 on the Zorki 3M. The tabbed J8 also needs to be relubed which I'm going to try to do myself (thank you Kim.) I need to get some better screwdrivers first. Until then I'm doing some tests to compare the two. If the tabbed J8 compares well to the black J8, it will live on the Zorki 3M.
It does look better on the Zorki 3M, doesn't it? The main reason I want a tabbed lens is that I can tell where it's focused just by feeling where the tab is and it's easy to zone focus by feel. It's also easier to focus since it only takes one finger. My 3M was made in 1955 and the tabbed J8 was made in 1958.
Since I'm playing dress-up with the Zorki, I put on the Leitz Summitar 50/2 that was on my Grandfather's Leica IIIc. It's in the que for a clean, lube, and adjust. It's suposed to have a wonderful vintage look opened up. I'm looking forward to using it in conjuction with the J8. Each has their own look.
And for maximum portability it's hard to beat the Tessar design collapsible Industar-50. My hope is that my 50mm kit will include all three tabbed 50mm lenses. Testing has begun.
Be very very carefull with the tabbed J-8, the metal is soft. you can literally bend the metal with your thumb around the filter threads. I took the glass out of a filter and keep it on mine permantely.........
I got my pictures back comparing my late black J8, with the silver tabbed J8, and Industar-50. They are all pretty close. There is no way of telling looking at 3x5s. I'm of the school that 35mm shouldn't be enlarged beyond 5x7 and I suspect the differences would not be noticable at that level of enlargement. The pictures below are at scanner resolution on my Epson 2450 (not the ideal 35mm scanner but good enough for comparisons.) Make your own judgements. I'm keeping the silver tabbed J8. Now to order those screwdrivers and lube.
