Leica LTM A very pretty fake?
Well, the serial number seems to be in the ball park, according to the list on Cameraquest.
I don't know much (if anything) about the leica 1's but it if it is not an original it is a good copy.
The shutter release button looks a little funky though.
I've got 2 photos of this model in reference books. The first is from the Leica Pocket Book, by Brian Tompkins. It shows this model with a mushroom type shutter release. Otherwise it is identical to what is in the auction. The second is from the Leica Manual and Data Book, Thirteenth Edition (1956) by Morgan and Morgan. It shows this model with the same type of shutter release as pictured in the auction. Both references show the Leica I (A) with a 50mm lens marked in millimeters. Later model lenses were marked in centimeters (5 cm).
The one in the auction appears to be missing its shutter release collar. Otherwise I can see no discrepancies between it and the reference photos.
Also, the interior view showing the shutter release spring is definitely NOT a Zorki or Fed. I think it's the real thing.
-Paul
-Paul
Thanks, I thought it looked funky, I just did not know why!
Yep, it looks to be the real McCoy, but the fresh looking paint on the top cover is a bit funky. Most Leica I cameras have that I've seen have that well worn look with the brass showing through.
There is something slightly odd in the bidding pattern on this one. On a "normal" auction it would only be about $65. The last 4 bids are all the same person and it doesn't normally knock the price up like that.
Kim
