absolute beginner - questions
Florian1234
it's just hide and seek
8:30 PM
All right gentlemen,
in order to enlarge some prints for the first time after one year (that time was embedded with in a course and not very fruitful) I might need some help from you passionate routinees.
I have an enlarger without possibility to change gradation (not sure about the English term). So, I need paper with fixed gradation, right?
When using PE-paper, which one should I take to get classic loking prints from my negatives? I want real blacks and a good contrast. How do I dry the prints?
Which developer do I need for the paper? The negatives are mostly from APX, Tri-X or HP5+ films developed in D-76. Is Dektol good then?
I hope my questions are somehow not too far away as a beginner and that you can help me a bit. Thanks in advance.
The paper grade should be selected based on the negatives and the desired results
if the negatives are normal contrast, you are good generally with grade #2 or possibly #3
if you want to lower the contrast of the results, select a lower grade paper. To increase the contrast , a higher grade
Check the enlarger carefully, most B&W condenser enlargers built in the last 25 years will have a filter drawer for Variable Contrast filters. Color enlargers will have 3 color dials that can be used with VC paper if you look up the correct settings.
You could just get some Multigrade filters and use them to get the grade you want (with multigrade paper).
I've tried a few paper developers and they made no difference to me, so I just stick with Tetenal which is available locally and in bulk.
martin
#2 graded paper is considered "standard", but results may vary among different paper companies. Another thing to keep in mind - VC paper printed without any VC filters falls into the general range of a #2 graded paper.
That being said, if I were you I would buy an under the lens VC filter kit (ilford makes one) - it is made for enlargers that don't have a filter drawer.
Check carefully if your enlarger has no filter drawer.
Otherwise buy the MG filter kit (for under the lens).
Suggestion PE/RC MG IV to start with. You can use any MC developer. For starting a neutral tone. You can always go to a more cold tone or warm tone MG developer.
Drying: on the air or a föhn (hair dryer).
A suggestion for your APX100/400 and Tri-X 400: Rodinal (Agfa) new brand label R09 one shot "made in Germany". But only if you like grain. 1+25 - 1+100 in dilution, easy in use (liquid concentrate), very long lifetime (>10 years).
Best regard,
Robert
Like everyone has said, check for a filter draw and use that, or arrange an under-the-lens set of multigrade filters.
I must admit that for drying resin-coated prints smaller than 40cm I just use a rubber coated clothes-peg (or two), at a corner, and hang them up to drip-dry. For bigger prints, or fibre-based paper, some sort of home-made drying rack would be better.
When using PE-paper, which one should I take to get classic loking prints from my negatives? I want real blacks and a good contrast. How do I dry the prints? Which developer do I need for the paper? The negatives are mostly from APX, Tri-X or HP5+ films developed in D-76. Is Dektol good then?
Paper comes in several varieties: fiber coated (can be either fixed contrast 0-5 [with 5 being higher contrast] or multi-grade) and resin coated (that is: plastic, which tends to be multi-grade). A multigrade paper with no contrast filters is probably about a grade 2-2.5. Resin coated papers can be hung from a clothes line to dry. They require little washing, but in my experience are less archival than fiber. Fiber papers do better if they are dried face down on a clean fiberglass screen (there are print dryers out there, but I think the expense is unnecessary if you are starting out). There are also blotting books of absorbent acid-free paper that can help with drying. If you use a hair dryer on fiber papers, you may get some curl to the paper (emulsion and fiber base can retain different amounts of water). "Real blacks" are a function, mostly of how much silver is in the paper and how much exposure you give it. Typically, for a well-exposed negative your first "true black" is a minimum threshold of exposure (i.e. time the enlarger light is on) through unexposed film base. You can expose more, but the blacks won't get any blacker.
Choose a developer that is easy to get; choose one and use it for a while. Dektol is good. Agfa used to make a liquid called "Neutol" -- also good. Sprint makes a liquid concentrate that can be diluted 1:9. Pick one and a development time that will be consistent (e.g. 2-3 minutes - do not vary it - this will become one of your controls for consistent result).
Good luck!
Ben Marks
