Adjusted the RF in GF670.
akk2
7:26 AM
3 SCREWS under the shoes. slot for vertical, Philips for patch focus adjustment and infinity.
you can push down the arm under the slot screw to move the patch down and turn the slot screw CCW and bring it up until it match.
I feel it is easier than RD1s and it is a better built RF.
You already needed to adjust the RF in your GF670!? :eek:
I don't think it really depends on the age of the camera whether or not one has to adjust the RF. If the RF gets knocked out of alignment it needs adjustment. That can happen within the first week of using a camera or after twenty years.
But it's good to know that this is an easy fix. I'm soon selling mine and so far the RF's still spot on but I'll make sure to pass on the info about the adjustment to the next owner.
3 SCREWS under the shoes. slot for vertical, Philips for close and infinity.
Are the close and infinity labelled?
wait, i am wrong, it should be finder patch focus adjustment and horizontal alignment. Which you will see the effect in viewfinder live time.
For closest focus the base length should be the other screw only can be adjust with top removed.
Awesome, thanks!
The simpler, linear RF mechanism of the GF670 seems to pay off here.
Still - does anyone know a matt screen/ground glass for focus check on the GF670/Bessa III that would work "as-is", for example from other cameras?
I am thinking of making a little kit to take on travels, to check focus and be able to adjust the RF on the go if needed.
I got mine used, and I find it accurate in close distance but obvious shift above 1.5m.
Is it sth I can fix on my own or should I get a pro to do it?
What size of screwdrivers did you use? i want to toss one into my travel pack in case calibration goes off on the road.
