My development time for Trix in a small tank (2 rolls) is 9 min. Now I am about to have a few rolls developed in a Jobo rotary processor, and I remember someone saying that time should to be reduced.
Does anyone know what this is all about? Sorry if I can't be more specific.
I used that Jobo rotary system extensively for about six months. I had joined a dark room and decided to switch from hand processing to cut down time. However, that was a mistake.
Personally, I would not recommend using a rotary system for black and white. The negatives that I obtained were no comparison to the ones done by hand that had time in between agitations. Even though you are using only 240ml of solution (D76 1:1 - 120ml D76 and 120ml water) this constant development doesn not allow time for the shadows to develop fully. This is because you have to cut down about 15% of your total processing time. I also recall Ansel Adams (not that I am sycophant) recommending hand over this system.
I also found that the temperature will rise higher faster as there is more energy generated with this electronic perpetual system.
So, on a sunny days with high contrast negatives, hand processing will always be preferable. On a cloudy day, then the system is good, but you have to test your speed controls.
Another reason that I don't like using this system, was that I like to monitor my tanks temperature by sticking a thermometer down its neck every few minutes. You can't do this when it is laid out horizontally. In this case of the system you have to trust that your water temperature is working. I find it easuer inverting it vertically in a cool water bath for those hot summer days, than monitoring the larger bath of the jobo processor. There is a little gauge to tell you the temperature, but I find the whole thing inconvenient.
So, in the end it all comes down to control. I love the control that hand processing gives you. I also love the negatives that hand processing gives you with the full 480ml of solution (240ml D76, 240ml water).
Anyway, they are my personal observations. I would definetely stick to hand developing.
