Adjusting rangefinder on Electro 35
xxjorelxx
Newb
5:08 PM
I just wanted to share some info on adjusting the rangefinder on the Yashica Electro 35. I recently acquired a Electro 35 that needed the vertical alignment of the rangefinder adjusted and after doing some research online, I found multiple sources directing me to the "YashicaGuy.com" website for instructions. The site is very informative however the instructions were somewhat difficult to follow for a camera newb like me. I was able to easily locate the horizontal/infinity adjustment screw right underneath the hotshoe but I could not find the vertical alignment screw for the life of me... so, I did some more research and eventually found instructions that were a lot easier to follow and I wanted to share it here in case anyone else was having trouble adjusting the vertical alignment on their rangefinder. Turns out that you have to align the vertical first then align the horizontal/infinity after.
Link to instructions: http://photo.net/leica-rangefinders-forum/00bvG9?start=20
Copied from link:
1. Remove two screws holding "Battery Check" panel
2. Use MEK or Acetone to loosen up "loctite" around adjust screw
3. Move gently and slightly until (a far distance target) vertically aligns
4. Infinity/horizontal adjustment access hole under hot shoe "shield/cover"
