Advice on cementing a beam splitter mirror.
Sporriegetta
12:58 AM
I've recently landed a DeMaria Lapierre Telka III in pretty decent condition. Unfortunately the beam splitter was pretty grubby. I found a company that can clean and recoat the mirror for me for only a few quid so I decided I'd take it out and send it off. Thankfully the mirror wasn't that bad but it had a coating of film - possibly the old glue, that was causing the blurriness. Because it was going off to be recoated I figured I'd have a quick go at cleaning it myself - and it's come up pretty jolly nice. I sat it in place carefully, looked through the viewfinder and it looks great. The next trick is cementing it in in a position that is close enough to use the camera's adjustment screws to align the rangefinder view correctly. I'm thinking that if there's a cement that can offer some resistance - kind of syrup like I guess, I could fine tune the positioning by eye then do the final adjustments. A cement that isn't going to gas off and create new problems down the track would be ideal. So my question is, is there such a product? If not what is the best product to use?
Sent from my iPhone using Tapatalk Pro
Like an optical cement or a regular glue?
I use canada balsam for gluing optical bits together. two part epoxy has worked well for me to glue things near lenses at least. I think it's cyanoacrylate (super glue) that gases off and leaves some haziness.
Where did you get the mirror recoated? I might want to redo my M2 viewfinder (again)...
It's the morning after the night before! Everything changed. I found I was able to clean my mirror and not ruin the coating so I've now done that. You can get it done though at scientific mirrors in London for between £10 and £20 though. http://www.scientificmirrors.co.uk/vcsm-Aluminising.html spoke to them on Monday and those prices are current.
So I used 2 part epoxy in the end. Prior to that I tried heat glue but it didn't bond well. So far so good although I'm yet to take it out. I'm going to run a roll of film through this morning. As for out gassing I can't find any specific info but other 2-part epoxies gas a lot when curing but very little after that. Fingers crossed!
Still sitting nicely. No major knocks to test it but. Little to no expansion or shrinkage during curing it would seem.
It still may move a little over time, like several months, from my experience with a professionally-replaced mirror in my Leica III. But it is just a matter of checking periodically and re-adjusting the rangefinder setting to compensate.
Ah ok. I can adjust horizontally with ease but vertically I'd need to break the mirror off and re-glue. I'm kind of prepared for that and am considering modifying the plate so as to be able to make it adjustable. I suspect with there being 2 brass rivets under the mirror plate and one third nodule on the camera top for the plate to locate onto, you simply filed them to align the mirror. Obviously I could be wrong though and it could be a simple turn of a screw!
