Aligning a D-2
BOSS65
12:20 PM
I am using a Versalab aligning tool on my D-2.
Aligning the negative carrier was easy. Next I checked the lens for alignment and it was off. If the negative carrier is aligned properly, does the lens / lens board need to be aligned? If so, how would adjust the lens boards. Would you check and shim each one? Any suggestions would be appreciated.
I just found this post today. The man you need to contact is Harry Taylor at classic-enlargers.com. He has an Omega help forum on his site and he is the rcognised expert for these enlargers. Here is a link to his help forum;
Ask Harry Forum
