xwhatsit
Hello Brian, or of course whoever else can help,
Just acquired a (cute!) little Elmar 90/4 in LTM. The serial dates it to 1949, and it's coated, reflecting a faint blue sheen.
It has a bit of haze, of course. A single spot of fungus behind the first element.
I want to clean it. It comes apart easily enough, but here I stopped. Normally I clean haze and fungus off very successfully with 50% ammonia and 50% hydrogen peroxide. I know, sounds a bit harsh. I think next time I'll use 1/3rd distilled water, 1/3rd ammonia and 1/3rd hydrogen peroxide.
However I hesitate to use this, as I've heard the early Leica coatings (and I'd assume 1949 is early?) are quite soft and ammonia will strip them off.
Should I be concerned? I tried straight distilled water and a bit of lighter fluid, but it didn't really clean it to my satisfaction. I'd like to try my normal mix, as it has a very high success rate, but I also don't want to strip off the coating.
How should I go about cleaning such a reportedly delicate lens?
Also got a Steinheil Culminar 135/4.5 LTM with the Elmar. Nicely made lens! Hope it performs OK.
Thanks all.
Thanks all.
