plummerl
A five day sale (4 days left) has started at Magnum: https://shop.magnumphotos.com/ in their Square Print series.
brennanphotoguy
Some good stuff in there this time. I'm sure I'll regret not buying more.
Pioneer
Thanks for the info.
A lot of the square prints on sale in this square prints sale aren't square.
filmtwit
Desperate but not serious
Someone beat to the punch line here!
plummerl
But they'll still fit in a square mat!
finguanzo
Yeah, I'm curious. Will the Matt still be 6x6.? So they just shrink the image to fit?
michaelwj
I got one last time which was square, but if I remember they all shipped in a square mat (and frame), you just get white space.
Edit: I was wrong, as you can see in this example
plummerl
I'm assuming that you realize you can get just the print. You could also order a frame from Frame Destination (https://www.framedestination.com/) for 1/4 to a 1/3 of the cost from Magnum.
michaelwj
If you click on an image, it will show you how it's shipped as a print with the paper size or in the frame (matted closely). Easy.
Jeroenduster
What are your two favorites?
dwojr
I like these two a lot:
https://shop.magnumphotos.com/colle...square-print-herbert-list?variant=30460915843
https://shop.magnumphotos.com/colle...uare-print-werner-bischof?variant=30421911491
Though there are several others I also really like. I've never bought a print from them before but I am really tempted this time.
brennanphotoguy
filmtwit
Originally I had this as group of 10 that I need to knock down to 3.
https://shop.magnumphotos.com/colle...uare-print-bruce-davidson?variant=30473996803
https://shop.magnumphotos.com/colle...m-square-print-matt-black?variant=30422110787
https://shop.magnumphotos.com/colle...-square-print-trent-parke?variant=30462610499
https://shop.magnumphotos.com/colle...num-square-print-eli-reed?variant=30472090883
https://shop.magnumphotos.com/colle...-square-print-matt-stuart?variant=30477024131
finguanzo
The reason I asked, not necessarily the mat, but the image. When you select the drop down to order the print, it says image is 6x6. A lot of the images are obviously not that ratio. Although the picture shows correctly. Which is the final print, 6x6 , or the correct aspect .?
Thanks
Thanks
plummerl
Thanks
If you select the Specs tab (below the image), it will show you the dimension of the longest side of the image. You can actually use the screen image to then get a pretty accurate number for the short side with some simple math.
I now have five images (just ordered a sixth for my daughter) and the long side (or square) is always 5.5 inches (14cm). The print size is always 6 inches (15.24x15.24cm).
