back alley
IMAGES
i think this is basic but i don't know the answer. up untill now my scanning was for the web but, if i want to scan with printing in mind, what size do i need to save the scan at?
for the rff gallery i usually save at about (long side) 800 pixels x ? so that it fits the screen but for a print do i need to save at a particular size so that it translates to a certain print size.
for example, for an 8x10 print is there a certain size to save at?
make sense, do i?
joe
make sense, do i?
joe
FrankS
Registered User
Hi Joe,
I'm not all that digital photo savy either, but with digital printing in mind, wouldn't you save at the max resolution your scanner is capable of?
bmattock
Joe,
Scanning size is somewhat disconnected from printing size. Printing size is a function of dots-per-inch on the printer, not on the screen. Very confusing stuff. Take a look at this:
http://www.wholesaledigital.co.za/m42home.htm
In general, though - I scan at 3200 dpi and that eqates to 4300 x 4600 or something like that - my 35mm scans come out at about 22 to 28 megabytes each. That would let me print very nicely at well past 8x10, and I never want to print larger than that, so I'm good. Hope this helps - I'm a bit fuzzy on the whole thing myself.
Best Regards,
Bill Mattocks
Best Regards,
Bill Mattocks
back alley
IMAGES
i'm not talking about resolution but the actual size of the image.
like for the book, we needed to save the image at something like 2100 x ?, i think.
as to resolution, i have read conflicting reports about what to save the image at.
for now i am saving at the second highest resolution that my scanner is capable of and at 1000 pix on the longest side.
i have a buddy with a good printer and he will print off some pics for me.
i'm getting curious about hard copies and printers now.
joe
joe
bmattock
Joe,
Sorry, that's where my knowledge just pooped out. I'm in the dark past that. I just save at max res on my scans and upload jpg versions of them to Walmart - get back slick 8x10 prints in about an hour, very cheap, look great. But I dinna know what would be the minimum rez I could get away with.
Best,
Bill
Best,
Bill
back alley
IMAGES
hey bill,
my scans seem to be around 200+ kb.
which is bigger mb or kb? doh!
i believe i have already mentioned elsewhere that math is not my strong suit...
joe
joe
back alley
IMAGES
hhmmm, i think we're outta sync here bill.
this stuff is confusing and i really don't know if my question is at all relevant.
joe
joe
FrankS
Registered User
megabites are 1000 times bigger than kilobites (I think). If you've got a buddy doing the printing for you, then take 2 files with you of a picture, one at max scanner resolution and the other at the second highest, and see what works best. Scan at 100%.
richard_l
The optimum resolution for most photo quality printers is around 300 ppi (pixels per inch), so just multiply the dimensions of the print (in inches) by 300 to get the pixel dimensions. For an 8" x 10" that would be 2400 x 3000. However, as the others have indicated, it's best just to save at the maximum resolution of which your scanner is capable.
back alley
IMAGES
that's a good idea frank. unfortunately i wasn't smart enough to start thinking about all this till i made a bunch of scans and saved them all at the same size.
i will follow your suggestion though, with the next batch.
joe
joe
bmattock
backalley photo said:hey bill,
joe
1mb is 1024kb. I only have to know that because my day job is software programming.
When I reduce my images to post online, I typically end up with a file less than 100kb in size as well. But I would not try printing that.
Best,
Bill
back alley
IMAGES
so, my 200 or so kb size scans are not gonna print well at 8x10?
damn...
joe
damn...
joe
S
shaaktiman
Guest
I think I understand your question, maybe this will help.
As a general rule, for inkjet printing, you want to scan to a size that allows you to print at 300 dpi. 200 is really the minimum though to get decent results. So, if you are printing something that's exactly 8 x 10, you want an image that's at least 1600 x 2000 pixels (to print at 200 dpi) and optimally 2400 by 3000 pixels (for better results at 300 dpi.)
You should also avoid "res'ing up" your image to get to the desired final resolution. It will get rid of the jaggies if your resolution is really way too low, but your image will just get mushy and soft instead. Scan at the resolution that you plan on printing at. So, if you're planning on scanning a piece of 35mm film and you want to print an 8 x 10 at 300 dpi, you should scan it in at around 2200 dpi, (not accounting for cropping.)
adam
adam
FrankS
Registered User
Film rules!
S
Scarpia
Guest
Today I received the May 10 edition of PC Magazine. There is an excellent article on this topic on page 72 and while it concerns itself with printing pictures from digital cameras the principles are certainly adaptable to scans. Try www.pcmag.com and if its not on there it is well worth buying a copy.
Kurt M.
Kurt M.
back alley
IMAGES
my head hurts...
joe
joe
S
schaubild
Guest
I always try to scan with the optical resolution of the scanner, in the case of the Nikon 8000 this would be 4000dpi. This gives me a lot of image information to work with (6x9 slide with 48 bit colour depth gives a ca. 340 mb TIFF). I do resizing and some sharpening if required just before print.
If I know I'm using the image only for the web I scan at 1200 dpi and work on it. Then again resizing, sharpening as last steps before publishing.
The reason for these procedures: I learned a long time ago from a pro that it's easier to make the quality of an image worse than vice versa. Just try to imagine you did THE shot, only to find out you degraded the quality to save memory and can't now get a decent output? So I shoot or scan with max resolution all the time. Just my 5 cent...
jan normandale
Film is the other way
Joe
most of these answers are pretty helpful regarding what you can do with a printer taking into account max dpi for that printer. The calculations are also pretty helpful and you should save those. Finally the advice to scan at max and then 'adjust the resolution' in the software .
What image management software are you using?
Jan
Jan
GeneW
What Jan said!
For images you want printed, scan at max resolution of the scanner. Then when you edit them, you'll need to crop the image to the proportions of the print size -- same as enlarging.
In PS or PSE this is easy. For your print image, select the crop tool and in the dialog window set the attributes to (for landscape)
Width: 10 in
Height: 8 in
Resolution: 300
Adjust image as wanted with levels and brightness controls, remove dust specks and scratchs, perform any desired dodging and burning, sharpen with a little USM, viewing image at 100% while sharpening, then Save As to a slightly different filename so you don't overwrite your original scan.
Think of your max-res scan as your digital negative. You can re-use it for different print sizes or sizing for the web.
Gene
Width: 10 in
Height: 8 in
Resolution: 300
Gene
RObert Budding
D'oh!
Take a look at the following site. You can also buy the info in printed format for reading in the John.
http://www.scantips.com/
Robert
Robert
