Any Ideas?
jimbob644
9:35 PM
I recently used my Contax G2 mounted with a 45mm lens to make some timed exposures. These exposures were anywhere from 2 to 4 minutes each. After development I found my film was fogged. This has happened to me before when I had a 21mm lens attached. I just blew it off -- thought maybe the roll was bad. I've had the camera nearly 5 years without any other problems. This is the first. This problem happens only on long exposures. I've got some light leaking somewhere. Any ideas on the cause? Film window? etc...
Maybe the viewfinder window? Try a test roll with black electrical tape over the film window and the viewfinder to try to partition the problem down.
