Any opinions on Zuiko 35/2.8 ?
Peter_Jones
8:12 AM
I'll find out soon enough (just won one on a certain auction site), but the OM 35mm f/2.8 doesn't seem as popular as other focal lengths in the Zuiko series.
Has anyone used this lens and how do you see the results compared to other Zuikos ? (I know there are many variables with these lenses)
I have a multi-coated 35/2.8 Zuiko and I like it a lot - I think it's every bit as good as the 28/2.8, and has very similar optical characteristics.
I have one, an older single-coated one, as well as a newer multicoated 35mm f2 Zuiko. The 2.8 is half the size of the f2, and takes the same lens hood as the 50mm f1.8 and 1.4 zuikos. I like it for its small size and compatibility with the 50mm lenshoods....makes an easy to carry small kit. Sharpness wise, I thinks its the same as the f2, at least at midrange apertures. I have not tested the 2.8 wide open, though the f2 is kinda soft wide open. The 2.8 has a very slight barrel distortion that is not seen in the f2, and that's its only downside so far as I can see.
I also have both, I think the only aspect that the bigger and heavier 35/2 excels at is at micro-contrast. Therefore resulting in increased apparent sharpness and more "depth" look.
Well, I'll have to wait to try a 35/2.8 as I have agreed with the seller to return it due to unacceptable scratches :(
Oh well. :rolleyes: At least my last slr lens purchase was a good 'un. (Tamron SP 28-80)
