Anyone got a good fix for busted Cosina viewfinder foot?
Vickko
3:39 PM
I've got a 21mm finder, and part of the foot, that slides under the rail of the accessory shoe, is broken off.
Vick
Ask the local Cosina representative for a spare part? These finders still are being made, so parts must exist. They might even give you one for free - the price of the ABS cast shell is negligible, all the value is in the glass.
How much is missing? The foot of mine is partially gone, but I can still use it, so I'm not even bothering with a repair...
My 21mm finder foot is also partially broken but it's not causing me a problem at the moment. At least I know I can order the part if need be. Thanks.
I fixed one for a good friend and fellow RFF member a while back. The replacement foot was machined from brass and should last as long as the Leica it's used on.
It took more work than I expected, so probably wouldn't be economical unless you've got a milling machine or a friend with one who owes you a favor. I believe that CameraQuest can supply replacement plastic feet for CV finders.
Glenn
