aperture /b/w/raw
Jerkman
12:59 PM
i am using aperture apple software. i have an epson v700 scanner and a plustek 7400. the issue is what scanning software to use :silver fast se 8 , or vue scan . raw or tiff, which one work s best in aperture for printing?
I use v700 to tiff via Epson Scan (2400DPI 16 bit grayscale or 48bit color) .
Send files to external HD from Eposn Scan and then import to A3.
I don't feel 3rd party SW is needed or an improvement over Epson Scan.
Have ordered prints to 11x14 from MF scans. They look great. For 35mm I keep it to 5x7 using the V700. It's not the tits for 35mm but, good enough for preview.
Can't help with the Plustek.
Question
Question
I have a similar setup with an epson scanner and Aperture.
I have not given much thought to the scanning side so I have a basic Question- why Tiff and why 2400 DPI? Also for 35mm, what is the average file size you're getting for a single exposure?
To the Original Poster- I hope you don't mind my asking the above.
TIFF because it doesn't throw away data when compressing/re-compressing data as jpegs do, and gives you the maximum amount of data to work with. 2400 because that is the about maximum (or maybe it's a bit more than) the scanner can really achieve. You are looking to get the maximum amount of data out of the scan, and then save it in a format which preserves the data. I don't scan 35mm on the Epson so I don't know about 35mm file sizes.
