R
ruben
Guest
If you intend to use the camera with a portrait tele (85mm, like the Jupiter-9) at closer distances, you can forget about the Socviet Universal finder - the parallax correction on that is a very bad joke, you will cut off parts of the person you are trying to take a picture of at least 2/3rds of the time. An added problem is that the foot of the finder is rather loose in many cameras, making it move slightly to the left or right.
This Universal finder is the number 1 reason that made me buy a Bessa R - only for the parallax corrected framelines!
Roman
Regarding the loose foot I solved it by force-pressuring my Kievs shoes.
As for the non accurate parallax correction the question is if we can turn the dial a bit more than recommended by the inscriptions on it, and how much. I suppose someone at the forum should have some experience with it.
Ruben
Roman
Ruben
