:bang:
Yeah, that's just how it felt today while preparing for Argust Day.
I had planned on using my C4-Geiss with all three Lithagon lenses (yes, I finally got a 135mm!), and spent a good portion of time yesterday cleaning them up. Then this morning when I took the camera out of the bag to practice mounting the Lithies, the shutter failed on it after one release.
So on to Plan B. Grabbed my trusty C3 with the Sandmar and Solinar lenses, and found out that the shutter had broken. One fast speed, and a really slow 1/10 was all it would do.
Okay, on to the back-up, a C3 that had the OEM lens cap I'd been meaning to try (the cap will not fit all my Cintars, as some versions have taller aperture setting ring pins). Shutter was good, and had the seven speeds which I thought might come in handy. But when I checked the rangefinder, it was several feet off at my test target nine feet from where I sit at the computer.
It's a good thing folks just give me Bricks all the time, as I have about eight of them (I've lost count). My never used Standard is packed away too deep for ready access, so I grabbed the Match-Matic from the display area. I was pretty sure everything was good to go on it as I test fire it every so often, and I cleaned and checked the rangefinder too.
Success! Now to mount the Nikon ZoomFinder, I slipped a cut-down accessory shoe cap into the meter shoe, and I was ready to roll.
Don't know how many frames I wasted using the wrong operating sequence. I started out winding the film after every shot, and promptly started forgetting to do so. Then I'd forget when I did wind on, so I had to switch to winding right before taking the shot. It's not like I was in any kind of a rush, as with the temperatures being in the high eighties to low nineties, I wasn't exactly running to the next shot location. Having an old, damaged brain out in the heat just doesn't get it anymore.
But I still had fun doing it, even though the one train of the day went by the crossing while I was a half mile down the road on a bridge over the James River. Later on a Track Inspector came by on his Hi-Rail, so I got a couple of decent shots since I had talked myself out of immediately changing out the 135mm Soligor when I figured I was done at the location.
Hope you all had better luck than I did.
PF
