Arista Kodacraft like tanks
fgianni
Trainee Amateur
12:54 AM
Hi
I got myself two (35mm and 120) Arista Kodacraft like Tanks ( thanks to Scott Brand ), but I dont' have a clue on how to use them.
Essentially there is nothing printed on the bottom that tells me how much liquid should I use, anyone has any idea?
Also is anyone aware of step-by step instructions on how to use them?
Thanks
To determine the miimum volume of solutions: put the apron in the tank and using a measuring cup add water till the apron is covered completely.
Longf time ago we used to carry the aprons and metal cans with screw-on lids as developing tanks. The downside is that you had to add/empty the cans in darkness.
bmattock said:
I will try to remember to get the recommended developer amounts when I get home. Mine are printed on the bottom of the tank - you might look at the bottom of yours?
Nothing, nada, niente, nihil!
Not on the outside nor inside, there is a chinese writing on the lid, but it's identical for both the 120 and the 35mm si I guess it can't be the amount of developer.
Oh well, no big deal, I can always measure the amount of liquid necesary to completely cover the apron.
