Automated DSLR Film Scanning Device
5:12 PM
Hi, I thought I'd share my latest addition to my goal of automating my personal film development and digitization.
I've used a lot of scanners and been quite disappointed with the colors and amount of effort & time required. I've grown quite fond of capturing my film/slides using a DSLR with a macro lens configuration and a color-temp adjustable light panel.
I had some downtime this week and roughed out this prototype (not a linear process - several iterations!). Video below.
Current Implemented Features;
1) Bluetooth connectivity (iOS app for selecting color profiles, exposure count, and DSLR/Smartphone device selection)
2) Stepper-based film advance & accurate frame positioning
Controllable color temperature backlight
3) Loader and Outfeed provisions for full rolls and film strips
4) Manual control for lining up the first frame or dealing with unusual frame sizes.
5) IR Camera control
Video of it in action > https://youtu.be/bssll8My03E
This is part of my broader effort to create an open source workflow library in support of 35mm photography, film development, and digitization (previous two projects below).
https://www.photrio.com/forum/threa...fp-yet-another-desktop-film-processor.164871/
https://www.rangefinderforum.com/forums/showthread.php?t=167908
As always, any feedback or requests are appreciated!
Thanks!
-Nathan
Does the device automatically detect the edges of each frame, in case the spacing is erratic?
No - it currently relies on relatively fixed spacing and gives the user a few seconds to manually override the alignment (using the control knob) and a couple of seconds after you stop fiddling with it it will resume its firing/advancing routine.
It also has a learning mode where you can adjust the spacing by lining up two adjacent frames.
I suspect it would be a challenging burden to accurately detect the frames (I think of the case where images are blown out).
Thoughts on that and how many cases of uneven frame placement you are aware of? If it is just +/- a bit and averages out consistently-ish it may be fine.
-Nathan
Wow, great proto type, looks very slick. I would be happy with a manually advanced version of this for my workflow.
