Get a thick rubber band to grab the ring that holds the eyepiece in and try to unscrew it. Make note of the glass orientation before dropping it out. If it is glued in, a dab of acetone should free it up.
Phil Forrest
Phil Forrest
I'm looking for a 28mm viewfinder for my Ricoh GR1 (for use with a 3:2 ratio). Is this Avenon viewfinder suitable for that? I would appreciate your advice.
