pepeguitarra
Anyone knows the difference between these two lenses, in terms of contrast, resolution and sharpness? Which one do you prefer?
201008-10-SP-400PR 35 copy by Gabor Samjeske, on Flickr
201105-11-M4Ps-LEGACYPRO-28AVENON-40ROK-15 copy by Gabor Samjeske, on Flickr
201010-LV2-M7-PRO800Z-50ZM-28AVENON 27 copy by Gabor Samjeske, on Flickr
Leica M4-P / AVENON 38/3.5 LTM by Gabor Samjeske, on FlickrVery intriguing combination of M4-P with 28mm framelines and huge (it seems) Kobalux 28mm VF on top of it.
At that time I was still wearing glasses so the 28mm frame lines of the Leica were of no help for me. The Avenon VF was really good.
Thank you, Gabor!
It is important for me as well.
Where are some reviews on this lens, but not on VF.
M240 + Kobalux 28mm by Earl Dieta, on Flickr
M240 + Avenon 28mm by Earl Dieta, on Flickr
M3 + Avenon 28mm by Earl Dieta, on Flickr
What a magical coincidence which could only happen on RFF! 😉
This just came with Canada post!
Used, with some noticeable, but not critical play in the focus ring (the ring rotation is slightly stiff as well), solid aperture clicks, LTM, 1 meter, six aperture blades Avenon MC.
The viewfinder isn't big in this version. Easy to take apart for cleaning, all metal and glass. The bad side - it is little bit blurry.
I'm going to check how this lens will perform of FED-2 and M4-2. I always wanted to try it in Winogrand style, RF camera with external VF and 28 lens.
I don't need it to be 0.7. I think, I'll be close enough to pedestrians at one meter. 😀
I sold my Canon 28/3.5 ltm when I got a Kobalux 28/3.5. I love the images from the Kobalux. It is a wonderful lens overall. I have never used CV 28/3.5 lens, so I cannot compare the two lenses here.
I am having both, respectively silver Kobalux 28mm.
I am not sure about Avenon, but mine silver Kobalux has close focus from 1m, while Skopar 28mm goes to standard 0,7m.
But I definitely prefer Kobalux output.
The hood is screw in and it vignettes with the filter. Without filter with hood on or filter only it is perfectly fine.
I owned the CV 28/3.5 in S-mount only briefly but liked the Avenon 28/3.5 in LTM mount quite a lot. I think that the CV tends to give slightly higher contrast photos.
A photo of the Avenon lens and finder mounted on a M4-P I had briefly
