Bad things going on inside my ql17 gIII.
hamradio
8:47 AM
duluth, minn.
So, for some reason lately, my ql17 started making a terrible clicking noise at the end of a roll. The camera will still let me advance the film (even at the end of the roll), but just make bad clicking noises. I also discovered that the whole takeup spool thing can easily slip...if I hold my finger on it lightly and advance it, the spool will stay in place.
Also, the film counter refuses to work after 12-14. It just keeps moving back to that point every time I advance it.
One more thing...anyone have any tips to get a sticky aperture ring to work a little nicer?
Thanks,
Devan
I had a similar issue with my canonet. It started giving winding issues, skipping a frame every 3 or 4 wind strokes. By the end of the roll the camera would wind but the shutter wouldn't cock. I'll probably have to send it out to be repaired.
I cleaned out the shutter and aperture blades of the same canonet to get it working. In the process I misplaced a small ball bearing which gave the click stops on the aperture ring. After reassembly the aperture ring doesn't click anymore, just a smooth motion. Not exactly a fix but I think I liked it better.
I assume, aperture clicks are just helpers (to don't easily change setting accidentally or say, set aperture without looking). Once ring is moved, aperture is set.
try a shorter roll in there. a 24 exposure one, or if you bulk roll then go for like 20 frames. if that fixes it, then...that fixes it 🙂. I had some slippage in the take-up spool on one of my earlier canonets and it was just that the grip on the take-up was giving way to the tension inside the canister from the longer roll.
Heh...I'm already using 24 exp rolls. 🙂
Thanks for the suggestion, however!
The aperture ring slipping is not an issue for me...actually moving it is tough...I have to grasp it firmly with 2 fingers, and it has a bad metal-on-metal feel when I move it.
