Beginner develope film at home
exe163
3:27 AM
I want to try to develop my own BW film at home. I shoot only Tri-X for BW. I heard a lot of people do D-76 1:1 and got good result. Right now I have nothing. I want some recommendations on what exact products to get, used or new, for a newbie to have an easy time doing it and student wallet friendly. Linked to the ad/product page would be superb. Please mind the shipping cost as well so if i can drive to target to lower the shipping, I would opt for that.
P.S. I live in Houston, if that makes a difference.
I just deleted a product list for everything you need to start. Rats!
Here is the list I came up with from the top of my head. Think I got the essentials..
Developer: http://www.bhphotovideo.com/c/product/26996-REG/Kodak_1464817_D_76_Developer.html
Fixer: http://www.bhphotovideo.com/c/product/253199-REG/Ilford_1984262_Rapid_Fixer_Liquid_1_Liter.html
Stop bath: http://www.bhphotovideo.com/c/product/169348-REG/Ilford_1893870_Ilfostop_Stop_Bath_500ml.html
Photo Flo: http://www.bhphotovideo.com/c/product/28195-REG/Kodak_1464510_Photo_Flo_200_Solution.html
Tank: http://www.bhphotovideo.com/c/product/536021-REG/Kalt_NP10113_Stainless_Steel_35mm_Tank.html
Reel: http://www.bhphotovideo.com/c/product/714526-REG/Hewes_EKC009_35mm_Stainless_Steel_Developing.html
Changing bag: http://www.bhphotovideo.com/c/product/70983-REG/Kalt_NP10102_Large_Changing_Bag_Double.html
Funnel: http://www.bhphotovideo.com/c/product/40127-REG/Paterson_PTP306_Funnel_4_1_4.html
Thermometer: http://www.bhphotovideo.com/c/product/66777-REG/Delta_12415_6_Precision_Darkroom_Thermometer.html
Empty jug (I use this to mix the D76): http://www.bhphotovideo.com/c/product/70862-REG/Delta_11140_Datatainer_Chemical_Storage_Bottle.html
Empty container (then I fill these up and store the one I'm not using under a cabinet): http://www.bhphotovideo.com/c/product/70860-REG/Delta_11120_Datatainer_Storage_Bottle_with.html
Mixing cup: http://www.bhphotovideo.com/c/product/101852-REG/Delta_12120_Mix_Up_Cup_20oz.html
You'll also want some clips (I use clothespins) and something to hang the film from for drying.
Trix
HC-110 (one Shot)
One Shot Stop Bath
Arista Orderless Fixer (one shot)
One Shot Hypo Clear
I find the Arista tank easy to load
Graduate Cylinders
Thermometer
digital timer
All the above plus a Syringe to dispense the HC110 accurately. It is prone to bubbles as it is so thick as to be hard to measure in a cylinder. I use a syringe and a length of pipe. Draw off the volume needed and there will be a head of air that was in the pipe. Ignore that as it will allow for the HC-110 in the pipe. then flush thoroughly into the final solution.
Allow me to add one question: the water in my house is coming from a well and it is extremely hard - with a high calcium content. Is this a problem or will regular developing / using the prescribed chemicals take care of this?
Doing the final rinse in distilled water could be a good idea. I've been thinking of doing that to reduce the possibility of drying marks... Anyone know if that works?
I use distilled water as a final 2 minute soak/wash and have good results
D76 1:1 is pretty standard. Results will be fine
I mostly use TMAX developer, because it's a liquid and easy to mix for one shot use
Powders can be a pain at times. D76 is a powder and you have to mix it all initially into "stock" solution then dilute 1:1 as you use it to process film
It's really easy to develop. Have fun
To OP: All the advice and suggestions here are good. I might change the suggested one-shot developer from HC110 to Rodinal. Both work great, I just find that the Rodinal will store for a longer time. I have Rodinal that was opened 20 years ago that still develops film. I don't recommend using such old chems of course, but it just shows how Rodinal will remain usable over long term. Rodinal stored sensibly will easily last you 6months, likely longer. Depending on how many rolls of film you develop, that could be an advantage.
I develop between 2-8 rolls a month. I mostly use Rodinal 1:50 for my usual developing (unless I'm specifically attempting a fine-grain film, etc.). My 1/2 liter (500ml) bottle of Rodinal will easily last me all year, and beyond. I store all photo chemicals in a cool location that is completely (or nearly) dark, don't leave the caps off bottles longer than necessary, etc.
One more thing. People everywhere (in US) are divesting themselves of their darkrooms now that digital has captured the average photo enthusiast. As a consequence, I see darkroom and film developing equipment piling up in local thrift and secondhand stores. I have 3 such stores in my town and they all have developing tanks+reels available for very little expense. Well, 1 of the thrift stores in town is oddly very expensive and often prices things above what they cost new. I point it out and they just look at me. Frustrating when its something I have an interest in.
Developing your own film at home is rewarding. I don't know what your experience level is, but if you have problems with the first few rolls, don't give up. I found that once I settled on the work-flow that worked best for me, I could achieve consistently good results with minimal effort and mess. Good luck and enjoy.
Check your public library for a book on black and white developing , which will most likely be from the 1970s. Millions have done it, it's not hard, you just need to get into it. I think asking people online for advice is fine after you learn the basics and want to refine your process; otherwise, you will get lots of opinions that may or may not help you when you are starting out.
I've written several more recently than that, e.g. Successful Black and White (David & Charles, 1992) http://www.rogerandfrances.com/photography/successful.html , The Black and White Handbook (David & Charles 1997), Darkroom Basics (Collins & Brown 2000) http://www.rogerandfrances.com/photography/darkroom basics.html and even an e-book a year or so ago: Black and White Step by Step, http://www.rogerandfrances.com/e-books.html
Seriously, I'd suggest that a 1970s book is now likely to be quite seriously out of date, with films, developers and equipment recommendations that are sometimes confusingly outdated.
Get a spare /expired roll of film and practice loading it onto the developing reel, practice this until you can do it without problems.
...Terry
ps another vote for HC-110 developer
But..................
Good luck if you can make soup you can develop film.
Can you develop film in soup, for instance, Tomato, Cream of Mushroom, Clam chowder, and what are the varied result?
I know you can develop film in Instant Coffee, Vitamin C, and Washing soda, as I have been having fun with the process called Caffenol. Numerous web sites and information on this process.
Fun, fun, fun...
I tried it on my Sandisk 32 Gb memory card... big mistake. Use film.
The film loading is the hardest part for my shaky old hands especially 35mm. Have fun.
David
Don't let that scare you off, though.
Loading film onto the developing reels will get easier the more you do it. You can practice in daylight with a dud (expired) roll of film. When you can see what you are doing and the problems you may run into in daylight, learning how to load film and correct problems in the darkroom or in your changing bag will be easier.
You will learn to do it by feel and being able to see what you are doing and associate the feel with what's going on before doing it for real will make it easier.
Loading film is like anything else - the more you practice and the more you do it, the easier it gets.
