Platinum RF
Anyone own this tool? not easy to find.
sevo
Fokutorendaburando
Dedicated ring keys are easier to use, but not really necessary on a lens like that, where there is some room to at least one side. Any adjustable lens key of suitable size with outward flat tabs would do. If you really want a dedicated one, find a piece of tube of the same diameter, and file down one end by 2mm except for the two tabs that fit into the lens ring slots.
Platinum RF
I think it is the film gate black the tube, you have to cut off portion of the tube.
sevo
Fokutorendaburando
Something like this:
http://www.micro-tools.de/en/Spanner-Wrenches-oxid/Spanner-Wrench-Cross-Opener.html
would certainly do.
would certainly do.
Platinum RF
Will try thanks Sevo
colyn
ישו משיח
I don't recommend using anything but the proper tool. Many of the retaining rings are tight and can be difficult to get off and spanners can slip and cause damage. A spanner will set in the slots at an angle and can damage the threads..
You can easily make your own version of the beljan tool with a small piece of metal tubing and a file.
Platinum RF
Find a proper diameter tube is a challenge
colyn
ישו משיח
I machined mine from a solid piece of brass round stock..
nampara17
Do you have the specs for the tool?I machined mine from a solid piece of brass round stock..
Chris Sherlock
This might help.
retinarescue.com
Regards, Chris
Retina shutter retaining ring dimensions
Shutter retaining ring dimensions for Retina cameras
