Bessa R2 dies in temperature below 0C
zenza
11:19 AM
My lovely Bessa R2 doesn't seem to enjoy cold weather. Usually after heading out in temperatures below 0C the meter readings flicker in the viewfinder and eventually die altogether. Is this camera in particular known for not enjoying cold weather? I understand ways to get around this issue (keep the camera warm, keep a spare battery warm, etc) but those don't really work with my method of shooting. I'm just curious if others have had similar issues with their R2.
For comparison, my R4A using the exact same battery has been happily shooting this week in -15C without issue.
My R2M is about the same as yours R2. My R was quitting on batteries in cold within hour or go.
Maybe not the same thing but my R flickrs off and on in the winter. And it doesn't really get that cold here in my area of California. I'm shooting usually in the morning in the low 40 degrees F. It has never completely quit.
Interesting, and a huge bummer for us Canadians... Really glad it doesn't seem to affect my R4A.
Ya, it flickers on off but eventually dies if I'm out for an hour or more. Obviously the camera still works, but losing the meter for the rest of the outing sucks.
Yes, I would hold to this particular R4A dearly.
My Nikkormat meter is fine in the cold as well.
Cold weather has always been a problem for cameras powered by button-cell batteries, and it's not just Bessas... although they may seem more affected because their LED meters shut off if the battery doesn't have enough power for accurate readings. Cameras with moving-needle meters may seem better because the needle still moves, but you may not be getting accurate exposure. (Meters with old-style CdS cells give overexposure as battery power falls off, so in mild cases you might not see any effect except whiter snow.) I know that some people who really like outdoor winter photography carry a selenium-cell meter specifically to avoid the problem of battery drop-off at cold temperatures.
Definitely enjoying the R4A way to much to think of getting rid of it!
Great info, cheers! I may buy a brand new set of lithium button batteries to completely rule out batteries being an issue. Just wanted to hear others' experiences.
Bessa R4M, Ultron-M 35/1.7.
No problem with batteries in -5C
https://flic.kr/p/2cNmewW
2cNmewW
I have a Bessa R2 and live in Finland. I have never had any problems in sub-zero tempertures. Meter works fine, but I have only used it in about -10 degrees Celsius at most. I am using a half-case, maybe it helps a bit?
Carry some spare batteries with you in your pocket (preferably in a container) so you'll have a warm set to change out when it gets too cold.
PF
I have a Bessa R2 and live in Finland. I have never had any problems in sub-zero temperatures. Meter works fine, but I have only used it in about -10 degrees Celsius at most. I am using a half-case, maybe it helps a bit?
Hey, thanks for commenting. Ya I'm starting to think it's a battery issue...
PF
Definitely an option but would prefer not to need to do this!
it can make a difference in is you are using alkaline or silver batteries, silver being the best
You may be onto something. Since making this post the meter LEDs flickr like crazy all of the time no matter the temp now... Been using the R4A too much lately though so I haven't gone to buy a new set of batteries.
Happy update. Seems it was just a battery issue and that the 'new' spares I had weren't actually good.
Got some silver oxide batteries and the camera is happily metering in the 0C temps we're still having here in Canada...
