'best' way to ship a print?
back alley
IMAGES
9:36 AM
…can't remember if i asked this already…
what is the best /safest/most economical way to ship a small print…say, 8x10 or 8x12…both mounted & unmounted?
if you were to buy such a print how would you want it delivered?
Ideally, flat. I had a board-mounted print done by "The Print Space" in London a few months ago and they used a couple of layers of thin corrugated plastic boarding (very light and extremely inflexible) and the print was received in perfect condition - despite the outer packaging having taken a bit of a battering.
I've had prints sent rolled in a tube and I've struggled to get them flat and mounted.
Ditto - flat, but rolled in a tube if there's no choice (eg large prints). If the print's important, sandwich it between hardboard or thin MDF (packages can be handled brutally!).
I send them in the cardboard tube they ship art prints in, a local framer saves them for me ... but then I'm cheap so my prints roll easily :D
They're small, you should send them flat. If you can, put them between a layers of thin plywood, foamcore or similar, then tyvek.
For larger try not to use document/poster tubes if you can avoid it. Large diameter tubes (PVC tubes are a good option) are better. On the receiving end the prints should be laid out with nothing laid on top ideally overnight before doing anything with them to relax the fibers.
After putting the prints into an envelope, WHCC shrinks the envelope on a piece of cardboard. The box is larger than the prints. They also put a lollipop into each carton! They also use some packing to fill the inside of the box.
Can't shrink wrap? Find a way to affix the envelope to a piece of cardboard that is as large as the box used for shipping.
I have bought shipping supplies here:
http://www.uline.com/index.aspx?pri...gclid=CPPn45HfuMACFahaMgod5FYAnw&gclsrc=aw.ds
Hope this helps you.
When you say flat, do you put it between cardboard or reinforce it somehow ?
Every time I've sent a print flat it ends up folded in the post before delivery :bang:
